Very basic glue constraints not working
prekabreki
I'm trying to set up a basic glue constraints rbd setup for my object.
At first I did it by hand but that didn't work. Now I've got the shelf tool setup as a failsafe, but still nothing.
When the the constraints are enabled the whole RBD sim locks up, not even gravity works. Without the constraints the object falls apart largely as expected but as soon as I enable the constraints the whole thing locks up.
I attached a hip file because frankly I'm a bit stumped, hope someone can tell me what I'm doing wrong.
NAT_EGG_FX_v003.hip
If anyone has an RBD sim that just won't work for some reason with constraints, check if you have tiny pieces.
I had some microscopic fracture pieces and the RBD solver decided instead of exploding to just not run.
