coins stacking noise (vops)
logix1390
Hello,
I have a line with points. I copied some coin geometry to each point so it looks like the coins are stacked on top of each other.
In vops I apply some noise to the line on the x and z axis so that it looks like the coins are not perfectly stacked .
My result is ok, however it looks like my coins are all slanted
I am not sure why I am getting this.
I will attach my file for anyone that wants to take a look.
Thank you.
coins_vops.hip
You don't have an up or N attribute defined, so the coin points are trying to compute N for you based on the path of the curve points.
If you explicitly define N and/or up, your orientations will behave the way you want. Try using a Point Wrangle to do this after you displace your points:
v@N = {0,0,1};
v@up = {0,1,0};
