captainbuckfish Posted June 24, 2018 Share Posted June 24, 2018 Hi, Need some help with this one. Making brick walls is one thing as its just one plane but when faced with a more complex object I am at a loss. This tube is supposed to be made of bricks. Is there a way to filter through the edges and delete out a pattern similar to the picture. THis would create a brick pattern and then I could extrude the mesh. I have seen it done to points using a delete SOP and Delete by range but can this be applied to edges? Kind Regards, Duncan Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted June 24, 2018 Share Posted June 24, 2018 You can promote the ranged point group to edges and dissolve those. brick_pipe.hiplc Quote Link to comment Share on other sites More sharing options...
captainbuckfish Posted June 24, 2018 Author Share Posted June 24, 2018 oooooo thats interesting. So simple a technique but very useful. Thank you for yu help will get onto this Quote Link to comment Share on other sites More sharing options...
