sibarrick Posted April 15, 2006 Share Posted April 15, 2006 Hi, How do you make a group menu choicelist replace and not append? That is I have a string parameter that has a choice menu that lets you pick named prim groups, but it seems to default to the normal append type, where each time you pick a group from the dropdown it adds it to the field. I want to just make it replace so you can only pick one group name at a time. So this is what I have at the moment PRM_Template((PRM_Type)(PRM_STRING|PRM_TYPE_LABEL_NONE), 1, &names[5], 0, &SOP_Node::primNamedGroupMenu), Any ideas how to modify this to make it replace? There is a PRM_ChoiceListType called PRM_CHOICELIST_REPLACE but I'm not sure how to combine it with the group menu type which is defined in the SOP_Node class as static PRM_ChoiceList primNamedGroupMenu; ta Quote Link to comment Share on other sites More sharing options...
edward Posted April 16, 2006 Share Posted April 16, 2006 I think you need to build your own PRM_ChoiceList then to use PRM_CHOICELIST_REPLACE ... something like ... #define POINT_GROUP 0x01 #define PRIM_GROUP 0x02 #define BOTH_GROUPS 0x03 #define EDGE_GROUP 0x04 #define BREAKPOINT_GROUP 0x08 static void buildNamedPrimGroup(void *data, PRM_Name *menuEntries, int thelistsize, const PRM_SpareData *spare, PRM_Parm *parm) { SOP_Node *sop; int value; sop = CAST_SOPNODE((OP_Node *)data); if (sop) { sop->buildInputGroups(0, menuEntries, thelistsize, PRIM_GROUP, 0, false, parm); } else { menuEntries[0].setToken(0); menuEntries[0].setLabel(0); } } static PRM_ChoiceList thePrimChoiceList(PRM_CHOICELIST_REPLACE,buildNamedPrimGroup); Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 16, 2006 Author Share Posted April 16, 2006 Cheers Edward. I thought it would be something simply There's no way i'd have figured that out for myself. Many thanks. Quote Link to comment Share on other sites More sharing options...
