Attribute value of the current prim in a for loop
What is the syntax to read an attribute on the current prim from inside a for-each-primitive loop ? I'm not sure what the foor loop context allows me to do in terms of closure and stuffs..
Just to be clear, I'm talking about this kind of loop: http://www.sidefx.com/docs/houdini16.5/model/looping.html
Block begin / Block end
Edited by AntoineSfx
If you are iterating per primitive, then a simple
prim(0,"[your attribute]",@primnum)
or
prim(0,"[your attribute]",0)
should work.
The @primnum doesn't need to be specified since there should only be 1 inside the for each loop anyway.
Does this answer your question?
Edited by iFight4theUser
or
should work.
No it does not. The context is a Block Begin / Block End loop, the one in Utility / For-Each primitive
5 minutes ago, iFight4theUser said:
I've tried a test. Let me know if I still do not understand the context.
Both trees yield the same result. Just depends on if the wrangle is set to primitives or points.
5b3556e28f777_Screenshotat2018-06-2817-42-44.thumb.png.e37ec24f2311ce492132861149fc7015.png
I'm trying to get the attribute value in the float field of an operator (say, transform).
