Proto Install
Has anyone used the proto_install program to make an archive for distribution?
In the help toolkit/html/intro/tools.html it says
  Quote
proto_install
This program can be used to package a DSO for export to foreign sites. The program reads a configuration file and creates an archive file which can be extracted at the foreign site by using the proto_install command.
The configuration file must be called MANIFEST and contains a list of files which should be installed. The structure of the file is:
command filename target_path install_mode
It thens goes on to explain everything except how to actually make the archive :blink:
Running proto-install itself yeilds this
  Quote
Usage: ...\proto_install [-l|-x archive]
  or: ...\proto_install -i <install_path> -p <archive>
This program will install prototype software for Houdini Prototype software includes plug-ins for Houdini which are not supported in the standard release.  There may be several reasons why the software is shipped as a plug-in instead of in the standard release.
If the -l option is given, the contents of the specified archive are listed.
If the -x option is given, the specified archive is extracted into
the current directory.
If the -i option is given, the first package matching the given name is
installed into the specified directory. (eg. $HH)
So it says how to extract but not how to package.... :rolleyes:
Any ideas?
The method to do that is likely itself unsupported. :P
You could try doing something like this for your MANIFEST file
r README 	 x 	 0666
c SOP_MySop.dll  dso/ 	 0555
c SOP_MySop.icon 	 config/Icons/  0444
Then from the same directory as MANIFEST and those files, run:
proto_install -p SOP_MySop
This should create SOP_MySop.idx and SOP_MySop.inst which can then be extracted as usual.
