Custom color ID AOV and crowd
Hey folks!
I'm working on a crowd scene. I set up an attribute to store unique RGB color for each generated agent. In the material builder I use bind parameter nose to incorporate the parameter. I set up the extra image plate too. It works properly with all other objects, but it doesn't work with crowd.
I need the RGB color I need to control the RGB and also export it as a text file
Cheers
Szabolcs
