asa Posted April 18, 2006 Share Posted April 18, 2006 Hello all. I am looking to have an image map some parameters on a surface in the fastest way possible. Simple case: A black and white texture map should change a map a surface point parameter (evaled each vertex) from 0->1. Using the pic() expression in a point sop is way slow. It works but I think it is not caching the image each time and rereading it in some very slow way. Working at 720x486 with a piece of geometry with 12000 verts is taking a couple of minutes per frame. I looked into VOP sops but there is only a texture3d() function and that takes i3d files. I suppose I could preprocess my textures to thin i3d files but that seems a bit limited. Is there another vop in sopland that would to what I want? Thanks all. Asa Quote Link to comment Share on other sites More sharing options...
edward Posted April 18, 2006 Share Posted April 18, 2006 Offhand, I don't know why texture() wouldn't be valid in the SOP context. However, I also don't see why tex() would be slow. The textures are supposed to be cached. It might be faster if you converted your picture to .rat format first though. Or perhaps use texni() so that it doesn't try to do any filtering. Finally, maybe your expression is being evaluated a lot more than you think it is. One thing to try is to use an AttribCreate SOP to assign the texture values to your points in one pass first. Then do all your complicated expressions using a second SOP. That way, you can more easily tell where the bottleneck is. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted April 18, 2006 Share Posted April 18, 2006 I believe the VEX texture() calls use/need shading derivatives to estimate the filter size and that's why they're missing from the SOP context. For the SOP context you can use VEX's colormap() function, which is also available as the "Color Map" VOP. Keep in mind however, that a VEX SOP won't be able to operate on vertex attributes -- only point attributes. HTH. Quote Link to comment Share on other sites More sharing options...
