Extended Ocean - Particle surface for masking
AdloffT
Hello guys, I'm facing a problem with particle surface sop for Extended Ocean, when particle separation is low, the fluid surface on bounding box apear normally, but when I decrease the particle separation the fluid surface desapear and only some splashes are meshing. When I disable the bounding box the surface mesh apear normally.
