Array Function VEX
MJNorris
Hi there,
I'm playing around with creating some custom VEX functions and came across something a bit odd that I just can't seem to get working.
If I want to create a custom function that returns an array, say a vector array I will need to declare the return type at the beginning, according to the docs the following should work
// A function which returns an array of vectors
vector[] rgb_array()
However if I run this in a wrangle I get a syntax error on line1.
Is this a bug? Or am I declaring my function type incorrectly?
Thanks in advance
m
Okay, I actually got it working but those who have a similar issue I needed to use the 'funtion' function as the VEX compiler seems to be getting confused
so ....................
//doing an explicit function declaration seems to stop VEX getting muddled up
function vector[] rgb_array()
    return { {1, 0, 0}, {0, 1, 0}, {0, 0, 1} };
  • Thanks 1
