AntoineSfx Posted August 8, 2018 Share Posted August 8, 2018 I'm trying to duplicate some geometry using a Block Begin then referring to the iteration metadata. ( There is one dopnet per instance, before the for loop. The result of the for loop it not the input of one dopnet) After the geometry passes through a dopnet, the detail value is set to the correct value on the first frame, but after that, the value is set again, using the last know value of iteration before that ( i.e numiterations - 1) There is something that I don't understand with the way objects are created in this setup. Quote Link to comment Share on other sites More sharing options...
