bonassus Posted August 21, 2018 Share Posted August 21, 2018 I'm found this point expression point("../instance1",instancepoint(),"Cd",0) to access the value of the first index of the Cd vector attribute. However i can't find any reference to this usage of the point expression in the help files. the help shows point(geometry, string attribute_name, int pointnumber) with the attrib string as the second parameter and the point as the third. When there are 4 parameters it appears that 2 and 3 are swapped. this makes sense but is this shown in the help? thanks Quote Link to comment Share on other sites More sharing options...
woodenduck Posted August 21, 2018 Share Posted August 21, 2018 Houdini expression vs vex function http://www.sidefx.com/docs/houdini/expressions/point.html http://www.sidefx.com/docs/houdini/vex/functions/point.html Quote Link to comment Share on other sites More sharing options...
bonassus Posted August 21, 2018 Author Share Posted August 21, 2018 Ah OK. thank you. Quote Link to comment Share on other sites More sharing options...
