oleg_k Posted August 31, 2018 Share Posted August 31, 2018 hello! is there way to get back animated constraint geometry from dop network ? i mean i`d like to have the same gometry that i see at dopnet that shows constraintnetwork node when 'show guide geometry' is on Quote Link to comment Share on other sites More sharing options...
Abyss Posted September 4, 2018 Share Posted September 4, 2018 Hi, I did a test and you can download it below. this is for glue constraint but I didn't try it for other cons but it should work. simply cached the constraint into a file and loaded it in SOPs. to get animation I used " transformpieces " SOP to apply constraint motion. hope this help. untitled.hip Quote Link to comment Share on other sites More sharing options...
