probiner Posted August 31, 2018 Share Posted August 31, 2018 (edited) I got a crowd cached sequence files and an agent folder(with bgeo, rig, clips, etc). File SOP is throwing an error, can't read the sequence and finding the agent path. "Unable to read file: < cache file path >" (this path is correct, it's on my system) "Error loading the rig. The following paths were searched: < agent rig file path >. (nearbyte offset 408663, line 1, column 408634) Backend IO" (this path is pointing to the agent file on another system) I noticed if I click "Delay Load Geometry" the SOP doesn't give error anymore and the spreadsheet shows the content. But I don't see a primintrinsic or something I could edit to make it point to the correct agent files path. I gave it a try with "Packed Disk Edit" SOP, but no luck Where can I access the packed agent external reference and edit it to point to the folder on my system? Thanks Edited August 31, 2018 by probiner Quote Link to comment Share on other sites More sharing options...
probiner Posted September 4, 2018 Author Share Posted September 4, 2018 (edited) RFE'd that missing agent rigs load without error and that the external reference of agents can be changed, like one can for packed disk prims with: setprimintrinsic(0, "unexpandedfilename", @primnum, "filepath"); Cheers Pedro Edited September 4, 2018 by probiner Quote Link to comment Share on other sites More sharing options...
