hairstyle_rasta for current hair tools
So, there is a file in the documentation named hairstyle_rasta that explains how to make dreadlocks.
I kinda of found how to start, but I'm stuck at:
Go to the Appearance ▸ Clump tab on the fur object.
It looks like there was  a fur object with tabs in the past, and I can't find some Appearance  / clump tab in the current default setup in 16.5
Also, I'm not sure where to do this
  1. Dive into the fur object > guides node.
  2. Attach a attribwrangle.svgPrimitive Wrangle to the INPUT_GUIDES node, making sure it’s display flag is set.
What is the "guide node" in 16.5 ?
