Creating multiple groups by point attribute
gfern93
Hello Odforce,
I'm trying to create groups based on the @P.y attribute of a bunch of vertical lines I have. I am almost there, but I'm not exactly a Vexpert and can't figure out exactly how to assign multiple groups with different names.
I'm able to create a string attribute with the correct name for the groups with
s@test = sprintf("%f", @P.y);
s@groupname = concat("group_", @test);
I tried using setpointgroup(0, @groupname, @ptnum, 1, "set") after this, but it didn't do anything, now I'm just stumped on how to approach assigning this attribute as a group.
Any input would be greatly appreciated! Thank you
Hey Amaya,
I'm guessing that your code probably works, it's just that you can't have a point ( . ), nor a comma ( , ) in a group name.
So in your setup every points of your lines must have had some non-int value, resulting in no groups created at all.
Try multiplying the position by 100 and add it as an integer to your group name, or anything that eliminates the point.
This is my attempt. Keep in mind that you need to set your wrangle to Run Over Detail.
int ptCount = detailintrinsic(0, "pointcount"); // Get the point count
// Initial attributes setup
vector thePos = {0,0,0};
string groupName = "";
for(int i=0; i<ptCount; i++)
    thePos = point(0, "P", i); // Get the position
    groupName = sprintf("group_%d", thePos[1]*100); // Create the groupName variable
    // For some reasons, the groups doesn't accept commas, nor points ( , . )
    //printf("%d ", groupName);
    setpointgroup(0, groupName, i, 1);
Here's a quick scene with that code.
set_group_by_Y.hip
EDIT :
.. Actually, here's the same scene but with your code, working.
s@test = sprintf("%d", @P.y*100); // %d to have an integer
setpointgroup(0, @groupname, @ptnum, 1);
set_group_by_Y_1.hip
Edited by Alain2131
  • Thanks 1
