excluding Points with specific ID from group
F10
Hello all,
I've got a rookie question, probably straight forward, I'm trying to select points which are not in a specified group with a nearpoint function (I'm getting the same result with pcfind and nearpoints).
I've got a series of point 'growing' in a solver creating lines. I've set an integer attribute 'source' before the solver so each connected points have the same source number. Then I need to select the closest point which is not part of the same line when these lines intersect. I've found out that :
 string grp = "!" + itoa(i@source);
should do the trick but it doesnt some how.
I'm missing something here, I'm sure it's straight forward, anyone has any idea?
Thanks a lot! cheers
Grouping_Question.hipnc
