Get name attribute from another node
mois23
Hi guys,
I'm stuck in a stupid problem. I have a blast node with one point. I'd like to get the name attribute from it and copy in another node (see picture attached). I tried point() expression but it doesn't work. Can't figure out how fix this.
Edited by mois23
Upload the same pic
In vex, we cannot specify geometry as relative path.
a. You may wire the MUDGUARDS into the second input, and the vex will be:
point(1,"name",0)
b. If you don't want to wire (or you cannot), you can add a spare input, and change vex to:
point(-1,"name",0)
c. Another solution, worse than b. Rewrite your vex to this:
point("op:/obj/yourgeoname/MUDGUARDS","name",0)
But this is probably bad, because if you rename anything in the path, vex doesn't update the code automatically, so this path gets broken.
d. You could make a new parm (Operator Type) on the wrangle node, and then use chs() in vex to evaluate the content of the parm
As regards spare input, it is described here:
http://www.sidefx.com/docs/houdini/model/compile
More is here:
http://www.sidefx.com/docs/houdini/io/op_syntax.html
Edited by ikoon
unwanted emoji autoreplaced b)
