Rival Consoles Posted October 20, 2018 Share Posted October 20, 2018 Hello, I'm trying to figure out this thing about UVs and polygons from vdb in Houdini and so far so good except for the new and nasty UV seams that are created after the transfer is done through attribute from volume. Maybe someone can shed a light on this, it would be much appreciated. So, i created a simple scene with the pig head, converted it to vdb (from polygons) and then back to polygons. My intention is to transfer the UVs from the original head to the converted polygons from vdb, just for studying purposes. I used the attribute from volume node and it worked almost great, the UVs are transferred nicely but with nasty distorted seams. Even though the UV seams get lost in the vdb conversion, the approximation performed by the attribute from volume node is quite good but i cannot imagine a solution to solve the distortion on the seams, at least through this approach. The attached images show the comparison between the original UVs and the transferred UVs to the converted polys from vdb. Any idea about how to clean the erratic distortion on the seams? Or, is it even possible to do such thing? Thanks. Quote Link to comment Share on other sites More sharing options...
Rival Consoles Posted October 20, 2018 Author Share Posted October 20, 2018 I found a solution, the voxel size is the answer. Quote Link to comment Share on other sites More sharing options...
fabrykanickow Posted August 10, 2020 Share Posted August 10, 2020 Hi, I have an issue with UV mapping transfer from .fbx file onto VDB after applying VDB from polygons. I think your 'attribute from volume' would be helpful. Could you please explain which volume node you have used etc. or send .hip file please? I'm still at very early stage and any help would be appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
