Aich Posted October 21, 2018 Share Posted October 21, 2018 (edited) Hi guys, I'm in trouble with the new Volume Source node. I can't import a simple VDB from SOP to DOP as a collision object, let me explain better. There is a Pig Head converted in VDB by Distance, it has got two attributes: surface and v. After creating a simple DOP Network, I've tried to import the VDB object by the new node Volume Source. I set the correct path, changed the source volume initialization from smoke to collision, changed the source volume paramter, turning its name from collision to surface (to import the attribute I got in the SOP pig head), but nothing appear in the scene view, it doesn't import nothing. I also tried to modify the field to match, setting surface as field to create, nothing happens again. I'm trying to solve it for a couple of hours but I'm still stuck. Can someone help this stupid beginner? Thank you in advance. Edited October 22, 2018 by Aich Quote Link to comment Share on other sites More sharing options...
