Export Obj's per UDIM
CaptainAhoy
48 minutes ago, davpe said:
or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers. or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers.
objperudim.hiplc
This is awesome! thanks! :)
Edited by CaptainAhoy
