CaptainAhoy Posted October 22, 2018 Share Posted October 22, 2018 Hi, I have this huge set and I am trying to split it into smaller parts. Is there a way to export obj's per UDIM ? Thanks! Quote Link to comment Share on other sites More sharing options...
davpe Posted October 22, 2018 Share Posted October 22, 2018 there is no way out of the box but if you have your uvs ready you can build groups based on uv tiles and then use Python to automate mesh splitting and export. Quote Link to comment Share on other sites More sharing options...
davpe Posted October 22, 2018 Share Posted October 22, 2018 or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers. or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers. objperudim.hiplc 1 Quote Link to comment Share on other sites More sharing options...
CaptainAhoy Posted October 22, 2018 Author Share Posted October 22, 2018 (edited) On 10/22/2018 at 12:30 PM, davpe said: or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers. or, you can actually do it quite simply with a loop containing file caching node inside. check the file attached. cheers. objperudim.hiplcFetching info... Expand This is awesome! thanks! Edited October 22, 2018 by CaptainAhoy Quote Link to comment Share on other sites More sharing options...
