symek Posted May 8, 2006 Share Posted May 8, 2006 Is ASAD slide projection equivalent to texture projection in terms of texture coordinates? I suppose not, since I see differences between projecting textures with uvTextureSOP from light and ASAD slide projection from the same light (I don't mean shading differences). But how to acheive in ASAD the same result as projecting tex from light via UVTexture SOP? I want to try light projection via own shader as described here: http://www.odforce.net/wiki/index.php/Ligh...meraProjections but first I should know where I was wrong in ASAD usage. thanks, SYmek. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 9, 2006 Share Posted May 9, 2006 Hmmm... I haven't tested it, but I think both methods (ASAD slide projection and UVTexture projection from the light) use the same basic principle to do the projection and should therefore give similar results -- except, of course, for the obvious differences in resolution: the asad light is working at the renderer's current shading rate whereas UVTexture's resolution is tied to the geometry receiving the projection (and the missing bits are interpolated). BTW, the asad light's projection is *exactly* the one that Jason outlines at the bottom of that wiki page (i.e: toNDC()). Here's the pertinent code fragment lifted verbatim from the asad_light shader: // Projector map if (slide != "") { pos = wo_space(Ps); // Transform into space of light pos = toNDC(pos); // Transform into NDC space Cl *= texture(slide, pos.x, pos.y, "mode", "decal", "border", outside); } What differences do you see? Could you post some pics showing the problem? Quote Link to comment Share on other sites More sharing options...
symek Posted May 9, 2006 Author Share Posted May 9, 2006 I made very simple scene to compare results and I can't see differences actually. Sorry, I should check this before making rumor on the forum. There must be problem in my real scene though, because in simplified example UVTextureSOP IS equal Asad slide projection in terms of coordinates. In my scene they are not. hmmm.... I will try to figure out this puzzle and publish serious results... "except, of course, for the obvious differences in resolution: the asad light is working at the renderer's current shading rate whereas UVTexture's resolution is tied to the geometry receiving the projection " you mean that current render resolution is involved in projecting texture via Asad shader? How this can by? No, wait, it's about texture resolution, right? In UVtextureSOP scenario texture is sampled in respect to geometry mircopolygons? and in ASAD shader, one pixel of texture equals one pixel on screen in light space? Does it make any sense? gosh.... SY. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 9, 2006 Share Posted May 9, 2006 you mean that current render resolution is involved in projecting texture via Asad shader? How this can by? No, wait, it's about texture resolution, right? I mean that the granularity of UVTexture's projection is the geometry's points or vertices, whereas for the asad light it is sub-pixels (at the render resolution). Quote Link to comment Share on other sites More sharing options...
