kfu Posted October 30, 2018 Share Posted October 30, 2018 Hey guys, I found this gif animation was very interesting, so decide to give it a try. Basically set initial vel for each packed pieces and emitter them at origin, it works fine if I set a large initial velocity. But if I trying to low the velocity to achieve the stacking/layering effect shown in the gif, the packed pieces get penetrated and won't stack up. Anyone know how to fix this? Or am I doing it wrong,maybe using grain? Any help please? gold.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted October 30, 2018 Share Posted October 30, 2018 the point attribute i@found_overlap might help you here. setting it to 1 will resolve interpenetration. also take a look at this video from entagma: 1 Quote Link to comment Share on other sites More sharing options...
kfu Posted October 30, 2018 Author Share Posted October 30, 2018 Thanks toadstorm, that reset id thing works like a charm! Also I found it hard to get the look right,the the pieces seems won't stack up like a little mountain but keep rolling down instead. Quote Link to comment Share on other sites More sharing options...
kfu Posted October 31, 2018 Author Share Posted October 31, 2018 So I improve a bit but still it's nothing like the 2d animation,I'm out of ideas of how to improving it. It feels unstable compare to the gif animation. Can anyone take a look at my file and give any tips or suggestions? Maybe the way I'm doing it is not the correct way? gold.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted October 31, 2018 Share Posted October 31, 2018 I think what might be happening here is that you're sourcing in new geometry, and it's overlapping with existing rigid bodies in the sim. This causes the existing bodies to be shoved out of the way, which introduces unwanted momentum. You could try scaling down the instances when they're first generated, and then slowly scaling them up over their lifetime until they reach their maximum scale. You could do this inside your SOP Solver DOP. You'd need to make sure that the id of each packed RBD is reset to -1 every timestep so that the collision geometry is recomputed. I think this would also make your simulation look a little more like that original Spirited Away sequence, since that pile started with tiny little nuggets that magically grow over time. Quote Link to comment Share on other sites More sharing options...
bloodhawk Posted November 1, 2018 Share Posted November 1, 2018 You can use a combination of these 2 methodologies to achieve that. Even the first one will be sufficient - Quote Link to comment Share on other sites More sharing options...
toadstorm Posted November 1, 2018 Share Posted November 1, 2018 here's my example scene file for this effect. i merge new RBDs into the sim every fifth frame via a SOP Solver, then scale up the transform primitive intrinsic for any primitives where pscale < max_pscale. grow_packed_rbds.hiplc 3 Quote Link to comment Share on other sites More sharing options...
