davedjohnson Posted May 10, 2006 Share Posted May 10, 2006 Does anyone have a script or other bit of hackery to convert shop_vm_surface to vm_surface? Here's my situation: I got a .geo file and a .hip file that has all the right shaders in it and everything renders fine, but I would like to use the "Render from file" option on the object instead of a file SOP. It works much faster in my render farm to do that. The problem is that if I use "Render from file", there aren't any parameters in the Mantra ROP to make it see the shaders correctly. So I did a test and if the .geo is using the vm_surface attribute instead of shop_vm_surface, it renders fine. I can't go back to the .hip file that created the .geo in the first place and change the switch in the Shader SOP, though that would work. Any ideas? Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 10, 2006 Share Posted May 10, 2006 It doesn't sound like you're using instances where you might want a different shader setting per instance (and so be forced to use your own per-point vm_surface attribute). If this is the case, then you *should* be able to just use a shop reference (shop_vm_surface). There's an important detail for this to work though: you have to make sure that all shops are declared in the IFD: MantraROP > Specific > Shop References = "Declare all SHOPs" Otherwise it won't get resolved. If you're submitting to a farm and using hscript, then you would: opparm /out/MyMantraROP ray_shop ( all ) HTH. Quote Link to comment Share on other sites More sharing options...
davedjohnson Posted May 10, 2006 Author Share Posted May 10, 2006 I tried setting this "Declare all SHOPs", but that didn't seem to work. If that's what is supposed to work, maybe I've found a bug. I'll look into that more. Dave Quote Link to comment Share on other sites More sharing options...
davedjohnson Posted May 10, 2006 Author Share Posted May 10, 2006 Well, it must have been due to the fact that I was trying this at 1:00am, but the Declare All SHOPs seems to work just fine. Of course, I did write myself a little script that changes shop_vm_surface into vm_surface. I didn't make it completely useable, in that you have to go into the script and edit /obj/geo1/shopnet1 to the name of whatever path to your shopnet is. But other than that, it seems to work pretty well. Dave ind2d.txt Quote Link to comment Share on other sites More sharing options...
