customizing netbox creation and other UI commands
Neon Junkyard
There are a few quality of life things I would like to customize in houdini but I'm not sure if its possible
If you create a network box in houdini it makes it completely snug around your nodes and I am constantly having to immediately resize it and reposition everything, In nuke I have it set up to auto-create backdrops with 200px or so padding automatically, is this possible in Houdini?
This problem is made worse due to houdini will automatically select the network box and all its contents if your mouse goes anywhere over the title bar.  So if you are drag selecting nodes across several network boxes it will select the entire contents of all of them.   Again Nuke handles this way better, it will only select the entire network box if you drag select over the entire thing, or specifically click on the title bar
The second part I dont have much hope for but is there any python solution to create netboxes with padding, and maybe further customization?
EDIT - Also looking to set some defaults when creating new scene views
Edited by Neon Junkyard
Hey man,
Have a look at this code on how to resize a network box in Python:
if hou.selectedNodes():
    sel = hou.selectedNodes()[0]
    pos = sel.position()
    parent = sel.parent()
    box = parent.createNetworkBox()
    box.setPosition(sel.position())
    box.addNode(sel)
    box.setColor(hou.Color(0.5, 0.2, 0.5))
    bbox = hou.BoundingRect(pos[0] - 4, pos[1] - 1, pos[0] + 5, pos[1] + 1)
    box.setBounds(bbox)
cheers,
Manu
  • Like 2
On 11/20/2018 at 4:09 PM, asnowcappedromance said:
Hey man,
    box.addNode(sel)
    box.setBounds(bbox)
cheers,
Manu
awesome! This is a great starting point, thanks for that
