Force python sop NOT to cook
AlexNardini
Hello guys,
I have some code running in a python sop witch is time dependent (using hou.intFrame() in there ) so the node cook every frame.
However, Is there a way to force the python sop NOT to cook but only cook when is forced ( for example with a call back)  ?
Thanks in advance,
Alessandro
Maybe you could try something with the "stash" SOP or scripts related to its functionality?
It can save geometry data to a parameter, if you load your geometry from there, downstream,
I would guess it will not "dirty the node" and request a cook automatically.
Edited by acey195
