Alex Hessler Posted November 21, 2018 Share Posted November 21, 2018 I assume I'm missing something obvious. When you have multiple redshift rops how do you specify which one is used for IPR rendering? The Render View only allows you select from Redshift_IPR ROPS. So I'd like to have a Redshift_IPR ROP for each Redshift ROP. How do you explicitly define this connection between the Redshift_IPR ROP and the Redhsift_ROP? The "Linked ROP" attribute doesn't seem to do anything. I'm a little lost. Please help. Thanks Quote Link to comment Share on other sites More sharing options...
