bind vector array in shader
nuki
Edit: Dammit, I uploaded the wrong scene.....
I want to set point positions to a value from a vector array with a geometry shader. But somehow I cannot bind the vector array properly inside the shader, it will always return {0,0,0}. If I bind a vector directly it all works as expected, but I really need to pick my position vectors from an array.
If you have time, please take a look at the attached example scene which illustrates the problem.
array_cvex.hiplc
Edited by nuki
