Postrender Script
What Hscript command should I use to execute mcp tool to convert sequence images to a movie after rendering finishes...?
Is it possible, that on Windows I can only output avi and hmv files is there any way to create Quicktime? or mayby I should have Quicktime Pro installed...?
thanks,
kuba
Try using the 'unix' command in hscript, look it up in the help. In this case you could use somthing like 'unix mcp' in the post-render box, and it will automatically run mcp. I'm assuming to get this to use the output file from your rop
unix mcp -f 1 300 inputfile$F.tga -o outfile.hmv
Just replace infile with the same expression used for your fileout in the rop. I have not tried it out. But I think this is along the lines for what your looking for.
Alternativly you could write a script to read in the expression used, and the frame range, and automate most of the process. I'll give it a try in the morning, and post what I come up with.
As for outputting to quicktime, I have no idea, never tried.
Best of luck
-MP
