Use button to set a variable value in a menu script with python
Mzigaib
I have a simple ordered menu that have python script that has a variable 'check', I want that a button on the same node changes the value of this variable, with hscript I just put 'set -p check=1' on the callback script and I can access this variable on my menu's script, how do I do that with python?
I hope that makes sense.
Thanks.
I have my function on my ordered menu list:
import os
def listDirs(check):
    result = []
    houDir = os.listdir(hou.getenv('JOB')+'/houdini')
    if check==1:
        for dir in houDir:
            result+=[dir,dir]
        return result
    else:
        result=["Nothing","Nothing"]
        return result
return listDirs(check)
I want my button on the same node to pass a value '1' to my 'check' variable in that function, how do I do that?
I did try on a callback button:
hou.pwd().parm('dirList').listDirs(1)
But it didn't work, what am I missing?
Thanks.
Seems like what you want is a semi-dynamic menu, which gets updated on request. You can do something along those lines:
In the menu script:
return hou.phm().my_menu_values(kwargs['node'])
In your PythonModule:
LIST_DIR = False
def my_menu_values(node):
  if not node.cachedUserData('menu_values'):
    node.setCachedUserData('menu_values', read_dir_or_something())
  if LIST_DIR:
  return node.cachedUserData('menu_values')
Then in your button callback:
kwargs['node'].phm().LIST_DIR = True
# force menu to cook
kwargs['node'].parm('my_menu').menuItems()
kwargs['node'].phm().LIST_DIR = False
P.S. Untested
Edited by Stalkerx777
