Bandu Posted December 27, 2018 Share Posted December 27, 2018 Hi guys, I need to check if Houdini 17 is running locally or on the farm and switch depending on it. thanks for helping me out... Quote Link to comment Share on other sites More sharing options...
anim Posted December 27, 2018 Share Posted December 27, 2018 Houdini on the farm is usually run in batch mode without UI and locally probably with UI if that's enough of a distinction for you you can use this function: hou.isUIAvailable() or you can just initialize an environment variable for your farm processes that may help you distinguish that more robustly 1 Quote Link to comment Share on other sites More sharing options...
Bandu Posted December 27, 2018 Author Share Posted December 27, 2018 YES ! thank you, works great for my purposes I knew it's simple Quote Link to comment Share on other sites More sharing options...
