Can't achieve the same wall distraction result as in a tutorial. What could be the problem?
Kapelan
I guess this topic is referred to those who were following Steven Knipping's Rigids tutorials.
I am trying to make distraction of a wall based on Steven's method where the wall is divided into clusters with one set of constraints that hold together as one piece and, another set of constraints (between the clusters) that represent the weakest constraints.
The idea behind this method is that when constraints break, the breakage propagates along the weakest constraints holding the clusters, with strong constraints, intact.
In my case this method is not working for some reason even if constraint strength=0. The propagation does not happen as in Steven's tutorial.
Here is my test file: https://ufile.io/8et37
This is Steven's result: https://streamable.com/gxefk
This is my result: https://streamable.com/9xhb7
What am I doing wrong?
