bugface Posted December 31, 2018 Share Posted December 31, 2018 Hey, I've been learning Houdini whilst at university and I've been using a pluralist tutorial to help me along the way with a certain piece of work. The problem is that I'm using version 16.5 and the tutorial was using 16.0. This has created some problems with using SOP's to delete the constraint network. I've uploaded the file below and have coloured the nodes to where I feel the problem lies. It would be much appreciated if someone could help me fix this problem, Thank you. Building_Destruction_Help.hipnc Destruction_House.obj Quote Link to comment Share on other sites More sharing options...
anim Posted January 1, 2019 Share Posted January 1, 2019 your file works for me in 16.5.405 I don't have other 16.5 builds installed to compare however if for you the constraints reappear check what values the expression in constraintnetwork1/Overwrite With SOP evaluates to you want it to be 1 on first frame of the sim and 0 on all the others, to bring the constraints just once and then allow them to be modified in dops from then on Quote Link to comment Share on other sites More sharing options...
bugface Posted January 2, 2019 Author Share Posted January 2, 2019 I went back a version from 16.5.571 to 16.5.496 and it seems to be working. Thank you for the help it was much appreciated, Connor Quote Link to comment Share on other sites More sharing options...
