Edit Chop Curves
kubabuk
I've imported some chops channels from the text file and want to edit rotation X channel and mirror translation values. I thought that this would be rather simple task, using transform CHOP, but I can't figure out how does it work!
Please HELP and thank's for any advice
Kuba
Solved out! In the file CHOP, "Name Options" has to be changed to "use new names" and append to the name of your channel the name the transform you want to change.
If for example column 0 in your txt file describes transformation in x, write chan0tx or anything ended with .......tx.
In fact Houdini's help is not so bad! ;)
Thanks SideFX!
