Blueprints to 3D Mesh
Here is a concept for turning blueprints into simple 3d meshes. Its basically carving silhouettes into a volume.
After getting the aspect ratio for defining the volume´s dimensions ...
res_front = hou.imageResolution(img_front)
res_side  = hou.imageResolution(img_side)
res_top   = hou.imageResolution(img_top)
ratio_side  = res_side[1] / float(res_side[0])
ratio_top   = res_top[1]  / float(res_top[0])
geo.addAttrib(hou.attribType.Global, 'ratio_s', ratio_side, create_local_variable=False)
geo.addAttrib(hou.attribType.Global, 'ratio_t', ratio_top, create_local_variable=False)
... a wrangle is carving the silhouettes into the volume from all three sides:
vector bbox = relbbox(0, v@P);
float mask_front = vector(colormap(image_front, bbox.x, bbox.y)).x;
float mask_side  = vector(colormap(image_side, bbox.z, bbox.y)).x;
float mask_top   = vector(colormap(image_top, bbox.x, bbox.z)).x;
f@density = min(mask_front, mask_side, mask_top);
The rest is a matter of converting to polygons, smoothing and remeshing.
blueprint_to_geo.hiplc
blueprints.zip
Edited by konstantin magnus
  • Like 5
  • Thanks 1
  • Haha 1
