Activate Posted January 19, 2019 Share Posted January 19, 2019 (edited) Hi everyone, I am wondering if somebody here would be gracious enough to help me with putting leaves on a tree. Here is the context, I grew myself some trees by implementing some standard algorithms: and am now looking to put some leaves on the trees. I modeled a super simple leaf and instanced it: I don't like the look of the leaves and I am not happy with their orientation or really the overall appearance of this. The process of growing trees gives me a lot of attributes to play with, e.g. the direction of the buds, the direction of tropism, the growth direction, the steps in the iteration, the degree of the branch, how much light a bud sees, etc. If somebody here with experience would be willing to put me on the right path I would appreciate it. Hip + geo attached. Thank you, Niels. tree_example.zip Edited January 19, 2019 by Activate Quote Link to comment Share on other sites More sharing options...
toadstorm Posted January 19, 2019 Share Posted January 19, 2019 You can just take those attributes you were using during the growth process and map them directly to v@N and v@up before you scatter leaves... the Copy to Points SOP will use those attributes to determine orientation. Similarly, you can take your number of steps, find the maximum, then use the ratio between the current step of each point on the tree and the maximum to figure out where you want to scatter leaves to. You also don't need to use the Instance object anymore for instancing in Redshift... Redshift can read Packed Primitives now without a hitch. Attaching an example. sample_tree_toadstorm.hiplc Quote Link to comment Share on other sites More sharing options...
Activate Posted January 19, 2019 Author Share Posted January 19, 2019 Thank you. That is providing some good food for thought. I had previously only attached leaves where buds had not grown into branches. I like your attribute wrangle to bias the orientation of the leaves. I will experiment some more Quote Link to comment Share on other sites More sharing options...
Activate Posted January 21, 2019 Author Share Posted January 21, 2019 I have not made much progress on the leaves but started with shading the trees. Not really what I asked about originally but here is the current look - most of this will not be visible once the leaves are attached as well. The tree bark is from a photo processed with Bitmap2Material to get the normal and displacement maps. The main challenge here was manipulating the UVs from Polywire, e.g. scaling the uv.y dimension by the length of the branches. If anyone here has feedback, I would appreciate it. Quote Link to comment Share on other sites More sharing options...
Activate Posted January 28, 2019 Author Share Posted January 28, 2019 Still trying to figure out leaves; some progress. 1 Quote Link to comment Share on other sites More sharing options...
Andrea Posted January 28, 2019 Share Posted January 28, 2019 (edited) From a CG point of view it looks cool. For sure after you fix a few things on the biological side it will look much more natural, if that's what are you aiming for. For example the leaves should be opposite or alternate to each other for the same little branch/twig. Since you used the L-system, maybe you can use it to get the right organization for them ( try give a look at this) I don't know if this can be helpful in your case -> A really helpful trick to drive attributes on plants is to scatter some points on the branches, give them a large radius and generate an SDF volume which looks like a blob. You can then use the distance from the leaves to the surface of the volume to decide if a leaf should die because is not getting anymore light for example. Edited January 28, 2019 by Andrea added link Quote Link to comment Share on other sites More sharing options...
Activate Posted January 30, 2019 Author Share Posted January 30, 2019 Thanks for the feedback. The trees are not based on L-systems. The growing algorithm is based on papers published by Runions and Prusinkiewicz. The orientation and position of the leaves is based on phyllotaxis which is really hard to see in the image. Here is a close up: It's possible that I am anchoring too much on where the tree simulation places the leaves and instead should just go with some scatter based approach of placing the leaves. Part of determining in which direction the buds will grow into branches is based on space colonization and a volume that circumscribes the outer extend of the branches. The volume gets filled with marker points and uses space colonization to select the buds nearest to each marker. Houdini is still pretty much a learning experience for me. Graphics is not really part of my background but it's a good creative outlet. Thank you. Quote Link to comment Share on other sites More sharing options...
