VEX_Sort not working in 16.0.736 (Solved)
Hey guys the original example from VEX_Sort is not working at least in my windows machine
I change the code
#include <UT/UT_DSOVersion.h>
#include <UT/UT_Array.h>
#include <UT/UT_Vector3.h>
#include <UT/UT_Vector4.h>
#include <UT/UT_Matrix3.h>
#include <UT/UT_Matrix4.h>
#include <UT/UT_Assert.h>
#include <VEX/VEX_VexOp.h>
using namespace UT::Literal;
namespace HDK_Sample {
    template <typename T>
    int compareValues(const T *a, const T *b)
        if (*a < *b)
            return -1;
        if (*a > *b)
            return 1;
        return 0;
      //Direct access to pointer value is not working in compare operator
        //return *a > *b;
    template <>
    int compareValues<const char *>(const char * const *a, const char * const *b)
        return strcmp(*a, *b);
    template <>
    int compareValues<UT_Vector3>(const UT_Vector3 *a, const UT_Vector3 *b)
        if (a->length2() < b->length2())
            return -1;
        if (a->length2() > b->length2())
            return 1;
        return 0;
        //return a->length2() > b->length2();
    template <>
    int compareValues<UT_Vector4>(const UT_Vector4 *a, const UT_Vector4 *b)
            return -1;
            return 1;
        return 0;
    template <>
    int compareValues<UT_Matrix3>(const UT_Matrix3 *a, const UT_Matrix3 *b)
        if (a->determinant() < b->determinant())
            return -1;
        if (a->determinant() > b->determinant())
            return 1;
        return 0;
        //return a->determinant() > b->determinant();
    template <>
    int compareValues<UT_Matrix4>(const UT_Matrix4 *a, const UT_Matrix4 *b)
            return -1;
            return 1;
        return 0;
    static void
        sort(int argc, void *argv[], void *)
        UT_Array<T>    *arr = (UT_Array<T> *)argv[0];
        // This will work with all types (including strings).  Since no strings
        // are created or destroyed by this method, it's not necessary to call
        // VEX_VexOp::stringAlloc() or VEX_VexOp::stringFree() to free them -
        // the pointers are just reordered in the array.
        arr->sort(compareValues<T>);
    static void
        decimate(int argc, void *argv[], void *)
        const UT_Array<const char *>    &src = *(UT_Array<const char *> *)argv[1];
        UT_Array<const char *>        &dst = *(UT_Array<const char *> *)argv[0];
        UT_ASSERT(dst.entries() == 0);
        for (int i = 0; i < src.entries() / 2; i++)
            // Acquire a new reference to the string for storage in the
            // destination array.
            const char    *str = VEX_VexOp::stringAlloc(src(i * 2));
            dst.append(str);
// Installation function
using namespace HDK_Sample;
void
newVEXOp(void *)
    // Sort the array by value for scalars, length for vectors, or
    // determinant for matrices.
    new VEX_VexOp("hdksort@*[I"_sh,    // Signature
        sort<VEXint>);        // Evaluator
    new VEX_VexOp("hdksort@*[F"_sh,    // Signature
        sort<VEXfloat>);    // Evaluator
    new VEX_VexOp("hdksort@*[S"_sh,    // Signature
        sort<const char *>);    // Evaluator
    new VEX_VexOp("hdksort@*[V"_sh,    // Signature
        sort<VEXvec3>);        // Evaluator
    new VEX_VexOp("hdksort@*[P"_sh,    // Signature
        sort<VEXvec4>);        // Evaluator
    new VEX_VexOp("hdksort@*[3"_sh,    // Signature
        sort<VEXmat3>);        // Evaluator
    new VEX_VexOp("hdksort@*[4"_sh,    // Signature
        sort<VEXmat4>);        // Evaluator
                            // Remove every second string in the source array and store the result
                            // in the destination.
    new VEX_VexOp("hdkdecimate@&[S[S"_sh,    // Signature
        decimate);        // Evaluator
