BrianK Posted May 26, 2006 Share Posted May 26, 2006 I just went dual head on my linux box for the first time. When I open houdini, it opens across both screens. I only want it to open on one. Is there a way to specify Houdini's window size at startup? Something in the 123.cmd maybe? Quote Link to comment Share on other sites More sharing options...
Jason Posted May 26, 2006 Share Posted May 26, 2006 BrianK said: I just went dual head on my linux box for the first time. When I open houdini, it opens across both screens. I only want it to open on one. Is there a way to specify Houdini's window size at startup? Something in the 123.cmd maybe? 28016[/snapback] You can alias "houdini" to something that uses the "-geometry" switch. "houdini -h" will list it as an option. Quote Link to comment Share on other sites More sharing options...
BrianK Posted May 26, 2006 Author Share Posted May 26, 2006 Jason said: You can alias "houdini" to something that uses the "-geometry" switch. "houdini -h" will list it as an option. 28017[/snapback] That's what I was looking for. Thanks! Quote Link to comment Share on other sites More sharing options...
