Houdini 17 can't finish every rendering
Hello there.
First at all, I'm not English people. So please forgive for my English.
I have a problem with Houdini 17 (Apprentice, 17.0.416) .
I fail every rendering even on "Render View" rendering.
It occur at any project file.
Error message is this.
Failed to save output to file "Traceback (most recent call last):
File "/Applications/Houdini/Houdini17.0.459/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/soho/python2.7/IFD.py", line 102, in
if not soho.initialize(now, camera, options):
File "/Applications/Houdini/Houdini17.0.459/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/soho/python2.7/soho.py", line 201, in initialize
_registerWranglers()
File "/Applications/Houdini/Houdini17.0.459/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/soho/python2.7/soho.py", line 169, in _registerWranglers
filelist = glob.glob(unicode(path + '/wranglers/*.py'))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe3 in position 25: ordinal not in range(128)
I'm using macbook pro, 2.6GHz Core i7, 16GB RAM, Radeon Pro 450 2048MB.
This problem doesn't occur at my Windows PC.
5c497b5817fe7_2019-01-2417_38_50.thumb.png.b1521853641b21a3387028ac61c6a484.png5c497b5bd4cff_2019-01-2417_38_34.thumb.png.c32541db5c3c91b15d661813b54977c0.png
Edited by Sunsheku
15 hours ago, Whatsinaname said:
Is it possible you are using a special character, that is neither a number nor part of the (English) alphabet anywhere in your scene (e.g. on your mantra SOP)? If so, do away with it and try again.
I changed all folder of Japanese character to alphabet, it worked!
It became able to render.
  • 6 months later...
Hello guys!
I think I have the same problem just like this! However, the above solution didn' work for me...
I'm pretty sure that I've named the file path and output path all with English characters.
I just tested this with rendering a simple box and using the default mantra.
I've tried both Houdini version17.5.173 and 17.5.229, and they showed the same error.
Any other solution? please?
By the way, I'm using an MSI notebook computer, Windows10.
Here's my error message:
Error
File "C:/MySoftware/SideEffectsSoftware/Houdini_17.5.173/houdini/soho/python2.7/IFD.py", line 102, in
File "C:/MySoftware/SideEffectsSoftware/Houdini_17.5.173/houdini/soho/python2.7\soho.py", line 201, in initialize
File "C:/MySoftware/SideEffectsSoftware/Houdini_17.5.173/houdini/soho/python2.7\soho.py", line 169, in _registerWranglers
UnicodeDecodeError: 'ascii' codec can't decode byte 0xa4 in position 22: ordinal not in range(128)
