Mplay frame range
Hello!
Probably a simple solution, but how do I match mplay's frame range to houdini when I render to ip? Let's say my houdini frame range is 101- 150. If I launch a flipbook, the range will be 101-150. If I render to ip, the frame range will be 1-50. Is there an easy way to correct this?
thanks in advance
