zhenkoest Posted February 1, 2019 Share Posted February 1, 2019 Can you help me/ Problems with displacing along normals in for -each node. how to attach them? it will be a planet will separated part with good detailing in unity. Sphere_displace_part.hipnc Quote Link to comment Share on other sites More sharing options...
bonsak Posted February 2, 2019 Share Posted February 2, 2019 Hi You dont need to use a for each loop for this. If i understand you correctly If you set an id on each initial polygon before you subdivide, you can use Primitive Split SOP to separate the islands in the bottom of the stream. -b Sphere_displace_part-2.hipnc Quote Link to comment Share on other sites More sharing options...
