Collision not working
ChazS
I'm trying to drop some balls on a grid but have no idea why the collision isn't working. Strangely enough, it's able to transfer color, so why aren't the spheres bouncing off the surface as well? I understand that volumetric geo is typically used for collision surfaces, but in the class I'm attending the instructor was able to make this work. So, for the sake of learning, I'm trying to duplicate the same collision behavior using the same kind of objects.
The file is attached if you don't mind taking a peek at it. Many thanks in advance.
sopMadness.hipnc
