evanrudefx Posted February 21, 2019 Share Posted February 21, 2019 Hello! I had a few questions about vellum. Whats the benefit of creating constraints in sop vs. dop? Is it possible to setup vellum and only create the constrains at dop level? It seem strange to have to switch in and out of my dop net to change values. I seemed to be able to get most constraints working in dop, but it seems the cloth constraint needs to made at sop level. Also, how do I animate values? I see there is a vellum constraint property node, but how can I animate values for a pressure constraint? It seems like the constraints are created first frame and not updated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 21, 2019 Author Share Posted February 21, 2019 I think I found the answers to my problems. IT seems you create initial constraints at sop level. if you want to add other constraints at a later time in the simulation then you can add them in dops. As for animating the constraints, I just output my pressure constraint to a group called pressure. I use that group in my vellum constraint properties node to only affect pressure. Quote Link to comment Share on other sites More sharing options...
