ChazS Posted February 24, 2019 Share Posted February 24, 2019 The latest version of the source volume dop has a new name (sourcevolume >> volumesource) but more so, tabs have been consolidated into one... I think?? At least it looks that way since the volume operation and mask components seem to reside in this new, single volume tab. Anyhow, here's a snip of both versions and my attempt to translate from version 16 to 17. Am I doing this right? Quote Link to comment Share on other sites More sharing options...
toadstorm Posted February 24, 2019 Share Posted February 24, 2019 (edited) Close... vel is a vector field, so you'll want to make sure you change that setting. You also might want to change your vel source mask field to density, but this is situational. The operation sometimes is better as a "copy" rather than a "add", as long as you have mask fields set up so you don't overwrite the whole volume. The shelf tools should give you a good example to follow. Edited February 24, 2019 by toadstorm 1 Quote Link to comment Share on other sites More sharing options...
