Moltenx Posted March 5, 2019 Share Posted March 5, 2019 I created a series on mini dirt explosions using particles to drive the force and create its shape, I've cached the particles. I wanted to turn those particles into smoke however with Houdini 17 update, I can't get it to work. I used a object merge to get my particles from my file cache, then applied a pyro source then attri noise to get density temperature and v then used an volume raster attribute to view the outcome. I see it but once I create the dop network, using volume source to get the null I created nothing appears in the dop network but I jump out one level and I can view it. Not sure what I missed or did something wrong. Hope these images help. Quote Link to comment Share on other sites More sharing options...
Andrea Posted March 5, 2019 Share Posted March 5, 2019 I am not able to see any errors from the screenshots. What are you visualizing in the 4th and 5th image? I can't see where is the display flag but you have some caches going on Maybe the visualization of the fields in DOP is turned off? Quote Link to comment Share on other sites More sharing options...
