pcloud en external data
davidyannick
I'm learning procedural modeling, I'm trying to find nearest points from a sphere with this
@Cd=0;
// point d'origine
int origin=chi("Origin");
// Distance séparant les points
float distance=ch("Distance");
// nombre de points à retourner
int amount=chi("Amount");
int target;
// retourne la position du point d'origine
vector pos=point(1,"P",origin);
printf("pos: %d\n",pos);
// stocke les positions des "amount "points à une distance de "distance"
int pcloud=pcopen(0,"P",pos,distance,amount);
if(pcnumfound(pcloud)>0){
    while(pciterate(pcloud)){
    // stocke le numéro du point dans target par référence
        pcimport(pcloud,"point.number",target);
        setpointattrib(0,"Cd",target,{1,0,0},"set");
and the vector pos is always 0,0,0 even if a sphere is plugged in 1 ?
I' ve found this example on youtube and it works ?
Thanks for your help
pcloud.hipnc
Edited by davidyannick
error
It took me quite a while to understand what is happening there :) looks like very overcomplicated code for a simple task.
vector pos is returning 0 as in code:
You are asking for P (position) from input 1 (your sphere) of the point number "origin" which in your case is "115" in hip you sent.
Your sphere has only 1 point (number 0). There is no point number "115" therefore it fails and returns {0,0,0}.
ps. You don't need to export output to terminal to debug this (using printf), you can just export global variable and have live output of your work in "geometry spreadsheet" @test = pos;
SideFX help file is very extensive and worth reading! Better than getting wrong ideas from youtube and potentially inexperienced people :)
Edited by tmdag
Shame on me I didn't see it ..
Thank you for your help next time I'll pay more attention :)
