Different SOP display flags on different scene views?
you can have scene views bound with different network views. so if you navigate in one node network you will only see it in the viewport bound to it while other viewport can show something different, if that's what you mean. you can use drag to vieport too. read Pinning and Tab linking section here http://www.sidefx.com/docs/houdini/basics/panes.html
Edited by davpe
I knew a bit about pinning and linking, but i thought this applies to networks paths and panes, not to nodes (display flags) inside a (SOP) network to panes. Is this true?
I would like to see (with like multiple 'blue flags') different stages of my SOP network in different Scene Views.
Edited by DévinOdforce
