SvenP Posted June 7, 2006 Share Posted June 7, 2006 I am having a problem with a shader i just started to write . The shader shows up fine in shops preview but only renders white in mantra . Maybe one of you knows a solution for that problem . Screenshot : Source: #define STEPMOD pow(dot(normalize(N),normalize(I)),4) #define STEPS r*2/stepsize float FalloffFunction(vector pivot,pos; float radius;) { return 1-pow(radius/distance(pivot,pos),4);} float DensityFunction(vector pos;) { float TotalDensity=anoise(pos*4,6,0.7,1)*4; TotalDensity=clamp(TotalDensity,0,2); return(TotalDensity); } surface Cloud( float r=.5; float stepsize=.01; vector pivot={0,0,0}; ) { int steps = STEPS*STEPMOD; vector marchdir = normalize(P-Eye)*stepsize; vector currentpos = P+nrandom()*stepsize; vector Cv = 0,Ov = 0; float TotalDensity=0; float Density; float Falloff; if(dot(normalize(N),normalize(I))<0) { int i; for (i=0;i<steps;i++) { Falloff = FalloffFunction(pivot,currentpos,r); Density = DensityFunction(currentpos); TotalDensity += Falloff*Density; currentpos += marchdir; } TotalDensity=TotalDensity/(STEPS); Cf = Of = Af = TotalDensity; } else { Cf=Of=Af=0; } } Quote Link to comment Share on other sites More sharing options...
sibarrick Posted June 7, 2006 Share Posted June 7, 2006 I haven't checked your code but I have come across this before when nothing was wrong but houdini just rendered white until I resaved the code into a different otl.... Quote Link to comment Share on other sites More sharing options...
SvenP Posted June 7, 2006 Author Share Posted June 7, 2006 I haven't checked your code but I have come across this before when nothing was wrong but houdini just rendered white until I resaved the code into a different otl.... 28414[/snapback] i already tried that but it doesnt help Quote Link to comment Share on other sites More sharing options...
sibarrick Posted June 7, 2006 Share Posted June 7, 2006 I just copy your code into an otl and it works fine. The only thing I did was change the name to v_cloud. So the code is good it must be an otl thing. Try the attached Cloud.otl Oh and I did this in H8 not H8.1 don't know if that makes any difference. Quote Link to comment Share on other sites More sharing options...
