fuse by smallest attribute value
Hey everyone, given a group of points within a search radius, I want to keep only the point with the lowest attribute value.
So basically 4 points are within 3 units from each other and I want to keep only the point with the lowest value of an attribute I have derived.
I thought the new fuse 2.0 sop in 17.5 could do this but If it can I am not using it correctly.
Any idea's? I can use a nearpoints and throw the points into an array but i'm stumbling on looking into that array and identifying the lowest value in the 1 to N points that are within the search distance.
Thanks, for any guidance.
